Hello. I have been working on this project when i get the time. It started in Novemeber and I am finally kicking it in high gear. Here are the threads I posted on another forum describing my build up.
The Kane Chronicles Part 1, 11-15-06
Fresh purchase of a $900 dollar GSXR.
As I start tearing the bike down last night I noticed some odd things about the bike. I am no expert on the GSXR series bikes but I saw some components that looked like they may be from the 600cc bike and not the 750cc bike that I purchased. This bike had standard forks and an unbraced swingarm. The 750 came with USD forks and a braced swingarm. This led me to do some research before I continued with the tear down. I checked the frame vin on a vin website and it is indeed a clean titled GSXR 750 frame. OK? So what motor do I have? I noticed the motor had coils in the valve cover for the spark plugs. The 750 does not have this. I measured the carb venturies and they are indeed 600 cc carbs so I took the engine code and looked it up. Yup, I have a 600cc motor also. It looks to me like some one procured (stole maybe) a GSXR 600 sometime ago and either had, or purchased a clean titled 750 frame. So now it looks like I have a legally owned bike with questionable parts. Who knows, maybe someone had a bent 600 frame and just bought a 750 frame because they got a good deal on it and then swapped it all out, I don’t know.
So know it looks like I have a mutt. No big deal though because it is going to look like one when I am done. I checked out the motor some more and it is completely seized. I need to take it out now and tear it apart to see the extent of the damage. If it is just crank bearing and they are scored then I can turn the crank and get some new bearings. Engine building is easy for me so this could be a good thing. I will get some thinner head and base gaskets to bump up the compression a bit also. If the motor is totally trashed then I will find myself a 750 motor and get some displacement that I wanted in the first place. It is all about cheap so the smaller carbs will go on and I might even swap heads to get more low end power due to the higher intake velocity that the 600 heads will allow..
Stay tuned for the next installment of the Evolution of a Streetfighter.
