321 - 340 of 349 Posts
Mr. Good Kat
Discussion Starter · #326 ·
As mentioned before you are an artist and you do that with the simplest things !!!!
Thanks @Bandit1052 ! It really means a lot to me!
Here is the so called "bike shed" I've built last year and gathered all my tools. 7m long and 2m wide.
Still need a small lathe and a TIG (even though I've never used a TIG, I think I can learn how to weld using one) to consider it fully equipped.
Cheers all!
Mr. Good Kat
Discussion Starter · #327 · (Edited)
Took off the sleeve that was covrering a part of the engine side clutch cable adjuster, and behold the rust. Well, I've cut the cable, removed the rusty part, created some sort of sleeve out of a stainless steel tube that I've threaded on the inside. All looks and fits good.
Pretty cheap to buy a new cable, but doing this is free and rewarding.
Now I just need to make the cable end out of solder.
Mr. Good Kat
Discussion Starter · #332 ·
@yantosh thanks, mate!
Today I did this:
It is a mould for making clutch / throttle cable ends. I've made it out of a piece of 1cm thick aluminum. The pictures are self explanatory and this system works great.
Just remember to fray up the steel cable before pouring the solder. And use some soldering paste on it so it sticks to the cable.
