looks good. I dont envy the time you spend keeping it clean but it does look good.
Thanks Yan! I was thinking to add some wheels as you can find on the shopping carts, that are able to move in all directions but I think that's ok as it is....maybe after I install the engine in the frame I'll build a shop chair that can be turned into an engine stand by simply removing the two bolts that hold the seat...hmmmthats a cool engine stand
Hopefully in the near future will be a full working bike and not just a stand 😁😂It already has a stand with wheels. Two wheels. And a steering too
This is one of my main issues. Usually I am not happy on how people are doing things.Just lower your standarts
As soon as you have a lathe, you immediately run into stuff or ideas that make you want a bigger lathe.Hopefully in the near future will be a full working bike and not just a stand 😁😂
Man I got so tired of looking for people to do stuff for me because I don't have the tools...I really need a lathe and a TIG machine.
Let me take a bath and will post a picture. Get yer welding helmets! 😁Show us all the shiny bits come on
If you can see orange, it means the grey Teflon coating has worn away and you're down to the metal....no wear on the bushings...
The copper bushings are fixed right under the oil seal. If you look closely, there are the mobile bushings with an intact teflon coating right under the copper rings. 😁If you can see orange, it means the grey Teflon coating has worn away and you're down to the metal....no wear on the bushings...
I think yours got to that point a while ago.
