1 - 5 of 5 Posts
So, I wanted to make a cheap bike. Like, beyond cheap. My purpose is to build skills and a semi cool bike is the bi-product (hopefully).
I started with a 1980 Kawasaki KZ250LTD which I purchased for about $250. The PO claimed that it had a bad starter. After some investigation I found that it actually had a bad starter clutch and the flywheel had a magnet broken in half. I managed to get the starter clutch back to working order but I couldn't get the flywheel ANYWHERE. The broken magnet caused the flywheel to be unbalanced and I feared that it would cause a problem in the crank down the road and that it may be unsafe to ride.
So, I tabled the project for a few weeks and kept looking for the flywheel. I was about to give up on the idea when I came across the opportunity to buy a Chinese clone of a XR200 for only $150. It was quite a beater to be honest, but, the engine ran great. I rode it all summer and never cared much about it until I moved to the city this last fall and no longer had space to ride it. Thats when I came up with the idea to swap the motor out of the dirtbike to the KZ. It has a stator, so I wouldn't need to really modify it much and the idea of kickstart seems cool
I dove in head-first. I pulled the motors from both bikes in one day. Turned out that the dirtbike motor fit in the rear two mounts without much effort but it was a mile from the front mount. I took the motor back out and cut off the original front mount. While I had the grinder out it decided to chop the rear of the frame about 8 inches, chopped out the battery box, stripped the paint off the gas tank and cut off the passenger foot pegs.
I knew that I would need to do some welding to get much further with the project. After a few weeks I finally bought a cheap welder at Harbor Freight and taught myself to weld on some scrap pieces of steel. After a few days of practice I had the confidence to weld on the Kawi. I started small by welding the rear of the frame up the way I wanted it to be, then I fabricated a front motor mount.
And thats pretty much where Im at. I could probably get better at welding, but, I've literally only been doing it for a week. I know its not really that cool, not worth the effort, not fast and so-on. But it's cheap. If it were a better bike I would never have had the courage to do this much and I would never get the skill I have attained. Please let me know what you think, and any suggestions you may have!
Oiler Boilereerer...er(s)
Important thing is penetration, you can get clean looking welds with practice in time.
1 - 5 of 5 Posts
