1 - 3 of 3 Posts
I have a 93 GSXR750 front end on my bike.
I found a place that makes GSXR front hubs (to run a spoked wheel), but they're for 2005-up. Here's the info I've got so far:
  • 1993 Front wheel has a 20x47x14 bearing.
  • 2005 has a 25x52x17 bearing.
  • Both 20x52x14 and 20x52x17 bearings are available.
The questions I have are:
  • Is the width of the wheel at the brake rotor mounting surfaces the same?
  • Is the width at the inner bearing stops the same? (eg, is the crush tube between the bearings the same length?)
  • Is there any way to retain the mechanical speedometer drive?
Thanks all!
Charles.
G
Surely if the guy is making hubs to fit 05 gsxr forks he can be persuaded to make some to fit yours ?
From memory the stock hubs are a different width between the early & late models & the yoke hole centres are different too
If i were in a position to have hubs made i'd take the whole front end to the guy & have him make up a hub to suit it helps him too as it allows him to expand his range without the expense of buying a front end ;)
1 - 3 of 3 Posts
