Installing LED front signals, they are separately wired 12V LEDs with built in resistor, The rears are also integrated LED lights. Even with all 4 corners wired in and working, the signals blink too fast as if I had a burnt bulb. Is this just because the resistance from LEDs is much lower than from an incandescent bulb? Can I swap the signal relay with one that will compensate for the new blinkers and have it blink at the proper rate?
Or should I just leave it and let them blink fast because it doesnt really matter
