1 - 2 of 2 Posts
Doing a custom seat with brake/turn signals on my S3. And I need help figuring out how the wires should be hooked together.
The LED strip has the following wires:
It is supposed to function as a running, brake and turn signal setup.
Red - Brake
Black - Ground
White - Constant
Yellow - Signal
Green - Signal
On my S3 I have the following colored wires (i have no idea which turn signal wire is for left or right at this point because I bought the bike non working).
I'm definitely not very strong with wiring things up. I need a drawing more than anything to help me twist these things together so I have a running light, brake and turn signals.
Brake: Black-Yellow-Grn/Purple
Turn Signal: Black-Grn/White
Turn Signal: Black-Grn/Red
I dunno bout your bike but I would run a test light to a ground then activate each signal. Figure out which is which on the bike. Then run them to the correct wire on the light. I crimp on bullet terminals to make it easy to pull things apart.
Looks good m8
rw
1 - 2 of 2 Posts
