1 - 8 of 8 Posts
Back again.
So it's been a solid year and some odd months since I've even seen my bandit. I have moved, started a new job and never had access to a garage. I can't say I'm 100% sure, but I'm pretty sure my keys were lost in the move. That being said, I have an automatic gas lid so I don't need the key. But obviously I need one to drive it.. What options do I have besides buying a new ignition with key
G
There is not really a simple option apart from buying an ignition with key, there are loads on ebay pretty cheap, just make sure its a genuine one not a pattern part or you will be cutting your wiring & fitting a resistor
Other options are fit any ignition or even a switch & re-wire to suit & fit the above mentioned resistor or try to find someone who can make you a key, I'm not sure how easy getting a key is where you are but its pretty impossible here in the uk
You can remove your ignition and take it either to your local dealer or a lock shop and they should be able to get a code and cut you a new key. Ran me 40 bucks but it was worth it
Back again.
I have a locksmith right down the road so that may be the best plan. I was also considering a RFID ignition. Not sure if I need a key for that ir not. Just started researching it
Most bikes have a code on the ignition cylinder somewhere that a dealer can use to cut a new key for it. A locksmith can fit a key also if you provide proof of ownership, I had that done once and it was $25.
An ignition is just an on/off switch. A rfid ignition is a relay that closes when your "key" fob gets within a certain distance of the receiver, usually a few feet. They're a lot simpler than people make them out to be, and can be fitted to virtually any bike with a battery.
Back again.
Would I need a key if I went to an RFID set up? I've wanted one since I saw my friend do his. If it's a better route, I should just go with that?
A good locksmith can cut a key to fit the ignition without using a code.
For rfid, either buy a motogadget m-lock system, or a latching relay and rfid kit off eBay. You bypass the ignition lock when you go rfid.
There is a thread about a diy rfid ignition in one of the subforums on here. You'll need the wiring diagram to go about it.
Back again.
Perfect. Thanks for all the help. I'll be heading to a locksmith after I check for the code. Looking forward to getting this project finished. Key and rear shock is really all I need
1 - 8 of 8 Posts
