1 - 6 of 6 Posts
Hello all,
My hiring harness is huge and obnoxious... looking to down size.
I purchased a KOSO slim line temp gauge and a small speedo so I will no longer need the connection for the stock gauge cluster. Also I don’t use front signals so there is excess wiring that needs to go.
My question...
How is everything connected within the harness? Can I simply cut and cap the wires I am not using?
I was going to purchase a 2005 Z1000 Harness off of eBay and cut it open.... then remove the wires I don’t use....is this possible:confused:
Any suggestions
Cant leave shit alone!
You could do it either way cut it up cap it and tape it off or take it apart meticulously and do away with what you dont need. If you choose the latter, do it in sections and retape or zip tie as you go or else it will turn into a real cluster fook quickly. Just my .02
Yea it's better to take the whole thing apart but its easier to just cut cap/tape/shrink wrap. If you do cut the whole thing open do 1 wire at time all the way out then the next then the next then the next then the next until you have removed what you don't want/need and neatly tape it back together.
1 - 6 of 6 Posts
