1 - 3 of 3 Posts
Enter here for the May 2017 FOTM.
The rulez:
minimum of 50 posts
4-8 good pics of your bike (and tell us which one you want used for judging)
list of modifications and such
must currently own said bike
past entries allowed providing
1. you did not win
OR
2. you've made measurable upgrades since last time
deadline is the 21st before we start voting
Entry posts only. All others will be cursed with broken bikes during the upcoming riding season.
k... Ill bite this time..
1998 Suzuki GSX-R 600
stripped and polished frame
milled pivot width for VFR arm
'97 750 engine w/ 600 carbs modified and jetted to suit
'02 gsxr 1000 to header
one off midpipe to fleabay oval mufflers
SRAD 750 yokes
'06 gsxr 1000 forks
'03 4 pad calipers with 15mm spacers
srad wheel and disks with 2mm spacers
2" billet bar risers
pro taper CR bar w one off stainless bar ends
'08 radial master w/ line converter and stainless lines
LED spot headlights on billet braket
carbon wrapped yzf 450 number plate w/ radiantz blinkers
'04 carbon front fender
trailtech vapour speedo
one off fridge filler overflow
R6 40mm throttle tube
Sprint steering stabalizer for k series GSXR adapted to fit
side stand lengthened 2 inches
carbon wrapped tank
GP Speedworks carbon tail
Graves seat foam
one off subframe and seatpan
Pro-tek rear sets
Rear master reservior delete.
'93 VFR 750 swing arm and wheel
one off linkage to adapt GSXR linkage
'08 GSXR 100 shock w/ one mounts
Aluminum chain guard/brake line stay
Radiantz LED taillight array on one off bracket
that's it mostly.. but prob not. all fab/mods/machining etc done in house..
good job if you actually read through that lol
first pic will do I suppose.
1 - 3 of 3 Posts
