1 - 13 of 13 Posts
All star !!!
I am going to be getting some sheet metal today to fab up a ghetto undertail for the Gix project..01 600..and I forgot to take the measurements last night. If anyone has access to their subframe and can take a couple measurements, I would appreciate it. I just wanna know roughly how much sheet metal I will need to go from the battery box area/rear pass peg mounts, all the way up to the end of the subframe. I need approximate length and width to basically close in the between the subframe rails. Rough measurement leaning on the wider side will work, since I will have to trim and mold anyway.
Ronayers says all these bikes use the same sub frame...FWIW:
Suzuki GSX-R600 2001 (K1) FRAME
Suzuki GSX-R600 2002 (K2) FRAME
Suzuki GSX-R600 2003 (K3) FRAME
Suzuki GSX-R600Z 2003 (K3) FRAME
Suzuki GSX-R750 2001 (K1) FRAME
Suzuki GSX-R750 2002 (K2) FRAME
Suzuki GSX-R750 2003 (K3) FRAME
Suzuki GSX-R750 2000 (Y) FRAME
Suzuki GSX-R1000 2001 (K1) FRAME
Suzuki GSX-R1000 2002 (K2) FRAME
Thanks, again, much appreciated.
DZ
British Bloke in Canada
josh(endo) has a standard GSXR 2001 750, tell him to get his tape out.
(cheers smiley goes here)
I'll measure it up right away tonight or tomrow morning there Doug.
If i don't go home or have time tonight, I Will tomorow !!!
All star !!!
Its all good..I can measure it tonight...I just figured I'd get the sheet metal today on way home if I had measurement...it can wait a day, but thanks anyway bro.
Hawk GT's are Cool
dougz, give me a min. Ill take some.
and here they are:
Hope thats enough for you. I got aluminum sheetmetal to do mine. If you dont have abunch of equipment metal cutting shears work best for cutting. on the length shot, your gonna need more than shown to go with the bends. I cant measure very good with one hand and trying to take a picture. And dont forget to wipe your paws, or the safety glasses.
All star !!!
Thanks bro...that tells me !2" X 24" sheets should work just fine. Thanks a bunch.
Function IS Form
19 Z900, 88 Kat11
I uses wood and clamps to bend sheetmetal... I guess all I really need is metal cutters and an electric wheel.
1 - 13 of 13 Posts
