Lol. Last to start, first to finishLate start, now I expect a come from behind victory!
You expect everything from behind.Late start, now I expect a come from behind victory!
Well played!You expect everything from behind.
You guys are silly.Well played!
I'm dealing with condo myself FUCK BONDO I HATE THIS SHIT. Next time I'm dropping the extra coin for a fresh tank
Ya I kinda figured that out when I did the tank. Its better than the front fender. However with cans there is always some over spray and particulate and shit. I am never painting stuff like this again. I will do it with a compressor in a garage or I wont do it at all.use thinner tape to lay the initial lines down. then mask the area with the wider stuff (or tape newspaper to the lines). thinner tape won't pucker leaving those gaps where the paint got under.
if you can't find 1/4" wide stuff, i've resorted to cutting up wider rolls.
Ill post one in a bit. You can still see its been bondoed. I am not too worried since my buddy will probably lay this thing down at some point.Looks like you're having as much fun with bondo as I am. Today is my last go at. If it doesn't work I'm buying a new tank
Could you take a pick of the side you bondoed and what looks like with paint and clear?
It was meant to be a 10' bike. Here are some close ups. Close you can totally see it even with all the filler primer i used. Need automotive shit to get it good.Lol I can see I sent in the top of it but I meant if you had a pic of the side where you bondoed it so I could see. I just finished my tank after putting on and sanding off almost a whole can of bondo but I now have it looking like it's not there it took 4 layers of filler primer 3 times wet sanding and depending on how it looks it the morning I might give it one more sanding.
