1 - 6 of 6 Posts
Hi
About a year ago i bought a dynojet 250 dyno and have been using it alot in my old shop. However, now i bought my own workshop so its time to set up a dyno room to last for many years. As I am writing this the room is not finished so i will post pics as i og. Questions and tips are very welcome :)
Started out by cutting a hole in the concrete floor. I really want the dyno pit mounted as i am also tuning shortcar which is a race series in Norway with bigger gokarts with cages and a 1000cc sportsbike engine. This will make it alot easier to get them on and off the dyno. Also with big touring bikes it will be a lot easier!
After alot of digging it was time for concrete
materials arrived
3 walls for the first set is up.
It will be a room within a room with about an inch of air between them. two sets of doors etc
Started to setup the fans on the roof of the room (flooring not finished but have to do something while waiting for more materials :)
Lights up and working. But alot more to do.
Fans will be controlled by these frequency converters. I will have start/stop swithches and potmeters to adjust the speed in the dynoroom.
More pics will follow as progress moves forward.
Hope to get some tips and inspiration from this thread.
Super Moderator
Man all yer getting from me is a jealous frown :D
Where are you located? Might have to come look at it up close if I ever get to do the fjord carving trip I've been planning...
Thanks, I`ll take it :) I am located in Horten, about an hour south of Oslo. You are welcome anytime :)
Fans built in separate room on top of dyno room to further reduce noise.
started to get a good setup. The big center tube will supply fresh air from outside while the other fan in the room can be used for extra cooling for radiator/oil cooler. probably wont need it, but better to set it up now than later.
1 - 6 of 6 Posts
