1 - 9 of 9 Posts
sickboy
Bearings aint the same size but anything is possible with skill and/or money. Get the front end then find a way to make your 92 kawi stem fit in the 06 kawi trips be it machining or making a spacer/sleeve.
No you want a steel/aluminum sleeve if you need 1. If you want the 06 triples and clipons you need the 06 forks as the 92 forks won't fit the 06 triples
i finally got everything put together I took the 92 stem and pressed it into the new tree with a sleeve and put a steel pin in it to just make sure all was good. works great and I love the new handling and suspension thanks guys for the wisdom much appriecated.
1 - 9 of 9 Posts
