i have a question, if someone could answer me that would be great
i connected lense and everything works except HI beam. at the beginning i thought that headlight is broken. but after i tested it on battery everything worked. only thing HI beam wire just lifts something inside lense and it opens up the upper part of beam. so i have to connect HI and LO beam wires at once. when connected to bike. Passing option lights HI beam. i checked manual for info on dimmer. it seems that it has only two optiions either HI or LO beam. i opened it up and saw that there is another place to solder in.
so my idea is to swap them on location on dimmer and make a bridge for LO beam, so it's always turned on. Please tell me if i;m wrong or no
i realise that switch will be the opposite. but it's still better than nothing.
also i could try to hook up it with passing switch. cuz that works
