So for you guys that like a detailed breakdown of what has been done to an already stupid sic bike then read on. For the rest, Just skip to the pics and enjoy.
Jason
2009 MV Agusta Brutale 1078RR Stealth Fighter
390 lbs, 175 hp, 93 lbs of torque
Bike built by Myself and Schmidt Racing did the throttle sync and remap.
Paint and graphics by JamAir Paint
Matching Bell Star Carbon helmet by Tecnoart Sersan of Italy
Many mods done, 100% Carbon Fiber Body Work styled and designed with a unifying paint scheme.
Full Titanium and Carbon Fiber modified Tamburini Race exhaust system w/ Carbon Fiber heat shields
Custom MV Corse Rider and Passenger Seat with Carbon Fiber cover
All vents and air intakes covered with anodized gold screens
BST Carbon Fiber Black Mamba 7-Spoke rims
MV Agusta LE Magnesium Swingarm and Hub
MV Race ECU Flashed by Redline Motorsports and PC V.
MV Corse front and rear sprockets by US Drive Systems (520) w lightweight DID professional race chain
AEM Magesium quick change rear sprocket carrier 14/40
Billet aluminum milled front sprocket cover
Billet aluminum milled shifter and brake levers
Billet aluminum 1 off custom swingarm frame plugs
All nuts and bolts switched to Titanium
Power Commander V
Scott Steering Damper
Rizoma Mirrors
Rizoma Passenger Pegs
Rizoma Handlebar end weights
Rizoma Grips
Rizoma Tail Tidy
Melotti Racing Reservoir Covers
Motovation frame/sprocket sliders
Ottimoto rearsets w Carbon fiber heel guards
MotoCorse Gas Cap
MotoCorse Brake and Clutch levers
MotoCorse Carbon Fiber Front and rear Fenders
MotoCorse Carbon Fiber battery tray
MotoCorse Carbon Fiber oil cooler cover
MotoCorse Carbon Fiber tail
MotoCorse Carbon Fiber upper and lower chain guards
Bestem Carbon Fiber Air Intakes
Bestem Carbon Fiber Side panels and Fuel Rail guards
Bestem Carbon Fiber Key Guard
Biondi Carbon Fiber front fairing
HID Headlight w Carbon Fiber housing
Oberone Clutch Slave
MV High output water pump
MV Slipper Clutch
320mm Dual Brembo Monoblock Brakes
Titanium Oil fill plug
Low-Profile LED Signals
Steal braid fuel lines
LED Rear Brake light w integrated turn signals
Blue LED dash lights
The words on each side of the bike on the panels below the seat are my daughter’s names meaning translated in Italian.
Aryana means “My Beloved” and Sabriyya means “Patient Rain”.
2009 MV Agusta BRUTALE 1078 RR - Specifications
ENGINE
Type Four cylinder, 4 stroke, 16 valve
Timing system “D.O.H.C”, radial valve
Total displacement 1078.37 cm3 (65.78 cu. in.)
Compression ratio 13:1
Starting Electric
Bore x stroke 79 mm x 55 mm (3.1 in. x 2.2 in. )
Max. horse power - r.p.m. (at the crankshaft) 113 Kw (178 HP) at 12500 - Lim. r.p.m.
Max. torque - r.p.m. 92lbs at 8100 r.p.m.
Cooling system Cooling with separated liquid and oil radiators
Engine management system “Weber Marelli” 5SM ignition - injection integrated system; induction discharge electronic ignition; sequential timed “Multipoint” electronic injection
Clutch Wet, multi - disc with mechanical anti-surging device
Gear Box Cassette gearbox; six speed, constant mesh
Primary drive 50/79
Gear ratio
First gear: Speed* 13/38 110.6 Km/h (68.7 mph) at 11650 r.p.m.
Second gear: Speed* 16/34 152.2 Km/h (94.5 mph) at 11650 r.p.m.
Third gear: Speed* 18/32 181.9 Km/h (113.0 mph) at 11650 r.p.m.
Fourth gear: Speed* 20/30 215.6 Km/h (133.9 mph) at 11650 r.p.m.
Fifth gear: Speed* 22/29 245.3 Km/h (152.3 mph) at 11650 r.p.m.
Sixth gear: Speed* 19/23 267.2 Km/h (165.9 mph) at 11650 r.p.m.
Final velocity ratio 15x41
ELECTRICAL EQUIPMENT
Voltage 12 V
Alternator 650 W at 5000 r.p.m.
Battery 12 V - 9 Ah Yuasa
DIMENSIONS AND WEIGHT
Wheelbase 1410 mm (55.55 in.)
Overall lenght 2020 mm (79.59 in.)
Overall width 760 mm (29.94 in.)
Saddle height 805 mm (31.72 in.)
Min. ground clearance 135 mm (5.32 in.)
Trail 101,5 mm (4.00 in.)
Wet weight 170 Kg (385 lbs)
Fuel tank capacity 19 l (5.02 U.S. gal.) - reserve fuel: 4 l (1. 05 U.S. gal. )
PERFORMANCE
Maximum speed* 277.2 Km/h (182.9 mph)
FRAME
Type CrMo Steel tubular trellis (TIG welded)
Rear swing arm pivot plates: material Aluminium alloy
FRONT SUSPENSION
Marzocchi
Type “UPSIDE - DOWN” telescopic hydraulic fork with rebound-compression damping and spring preload external and separate adjustment
Rod dia. 50 mm (1.97 in.)
Travel on leg axis 130 mm (5.11 in.)
REAR SUSPENSION
Type Progressive, single shock absorber with rebound and compression (High speed / Low speed) damping and spring preload adjustment
Single sided swing arm: material Magnesium
Wheel travel 120 mm (4.72 in.)
BRAKE
Front brake Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking band and aluminium flange
Front brake Dual Brembo caliper Radial-type, single-piece with 4 pistons - Ø 34 mm (Ø 1.34 in.)
Rear brake Single steel disc with Ø 210 mm (Ø 8.27 in.) diameter
Rear brake caliper With 4 pistons - Ø 25,4 mm (Ø 1.00 in.)
RIM
Front: Material / size BST Carbon Fiber 3.50 ” x 17 ”
Rear: Material / size BST Carbon Fiber 6.00 ” x 17 ”
TIRES
Front 120/70 – Dunlop GP-A (58 W)
Rear 190/55 - Dunlop GP-A (75 W)
Jason
Power Commander V
Rizoma Mirrors
Rizoma Grips
Rizoma Tail Tidy
MotoCorse Gas Cap
MV Slipper Clutch
ENGINE
Starting Electric
Primary drive 50/79
Gear ratio
Voltage 12 V
PERFORMANCE
FRAME
FRONT SUSPENSION
Marzocchi
REAR SUSPENSION
BRAKE
RIM
TIRES
