1 - 8 of 8 Posts
Hello everyone, i'm new here and thought i'd better say hello. I've got a few bikes and found this forum when looking for some rebuild info on the internet.
Here's a picture of the bike i'm working on at the moment, picture from last winter, XJR1200 with a FZR1000 RU front end. Thanks for having me.
WP_20210210_10_52_59_Pro_LI by Billy Bananahead, on Flickr
Welcome in, how does it handle the USD front end?
Thanks. At first i thought it was ok and after a while thought no this is rubbish, running wide on bends, maybe i was getting used to the characteristics. I commented on the XJR forum that i thought the FJ1200 forks i'd used beforehand were better. Anyway, someone told me to stick with it so i wound up the damping a bit and it seemed to like it a lot better. So i came across another FZR1000 USD front end and thought i'd renovate the forks before fitting them and glad i did because a previous owner had put the wrong springs in and so i bought some Hagon progressive springs and some Nitro shocks and just waiting until i get back home before MOT and trying the new set up out. I'm fairly confident it will be much better now. Phew that was a bit long winded, lol. I've got a few bikes and ride them in rotation and so it all takes time for things to sink in.
You most probably know this but have you tryed different tyre pressure in, I've found on my different bikes the tyre pressure can make a big difference and I'm only saying 2-4 psi.
My gsx1100et (well it's got a b12 motor different running gear etc) I usually run it at 36psi front but if I let it go down to 34-32psi it handles like sh#t.
firestorm's are like that
Welcome in!
Sorry for the late reply.
Yes, i know about tyre pressures. I always ride two up and before each ride set the pressures at 36F and 42R.
As i said, i adjusted the front suspension to a bit harder setting and it did make a difference.
I'll be able to play with it a bit more this week when i get back home.
Thanks for the tip though.
1 - 8 of 8 Posts
