1 - 13 of 13 Posts
Hello all,
Have not been on in for some time...
I re-routed parts of my wiring harness and moved around my control cables today...
When I went to take a test run the bike would accelerate up to about 6000rpms fine.... But when I went to give it gas the bike would rev higher but it wouldn't go any faster?:nuts:
Any thoughts?
Thanks
Fast ZX-12R
RPM's went up but bike didn't go. Slipping clutch?
re-tarded
If the revs go up and the bike doesn't speed up, the clutch is slipping.
If you're lucky you just have the adjustment wrong and don't need a new clutch
Reactions: ROBBO and shotgun
Ideally you want a slight amount of free play in the lever, like 1/2" or so before you feel it start to actuate the clutch. If there's no play and you keep a bit of tension on the throwout all the time it'll wear out prematurely.
1 - 13 of 13 Posts
