Welcome to Custom Fighters :haelo:
Blackin out yer frame?
I'm blacking EVERYTHING I can out to be honest, except the paint job. That is going to be something special.
I'm going to put the 1000rr rear sub-frame on, going to custom fab a front headlamp, swapped the stock forks for 03 750 forks, adding fatbar and risers, and some sort of non-stock, unobtrusive speed/rpm indicator. I want to order a belly pan - or I may just make one myself (its waaay cheaper!). I am toying with radiator shrouds but I want to get the bike together first so that I can get an immediate look at aesthetics as that design element evolves.
My biggest concerns (such as they are) about this project right now are:
1. Sprocket selection. Right now I am sitting on the idea of -1/+2 to give it a bit more low end around town. I think that will be sufficient.
2. Painting the engine. I am not a mechanic and cracking the engine apart to paint it scares the shit outta me. I am continuing my research on paints, but its the actual engine tear-down that bugs me.
3. Posture. I plan on putting in a 10mm washer on the rear shock. I do not know if I should drop the front any to give it a more aggressive stance. On the track, I never did this to the front - I wanted all the ground clearance I could get, plus 10mm rise to the rear end definitely improves Gixxer handling overall.
4. Enthusiam. I have found that I have a very difficult time controlling this driving impulse to happily acquire the parts I need to get this project off the ground - regardless of funds... This is almost as bad as racing!!
I will post up pics in the general forum. Thanks for the welcome!!
John
