1 - 15 of 15 Posts
I shit awesomeness
hot bike!
Post some info on the bike and what you've done. I'd like to know a little more about the exhaust and the aluminum swingarm.
Frame:
- MotoGPWerks aluminum racing swingarm
- Custom seat loop welded into rear of frame
- All Balls Racing tapered steering neck bearing
- NHK 7-way adjustable steering damper
- FFTP Billet aluminum fork-mount damper bracket
- Custom designed and waterjet passenger peg mounts/chain guard ? powdercoated
- Custom waterjet ignition relocation - powdercoated
- Dime City Cycles 2-up seat
- Dime City Cycles billet aluminum upper triple - powdercoated
Engine:
- KPMI racing valve springs
- Viton valve stem seals
- CB650 cam (increased duration)
- Re-ring?d pistons with OEM Honda pistons ? all bores honed within factory tolerance
- Powdercoated cam cover, breather cover, stator cover, drive sprocket cover, aftermarket finned starter cover, oil pan, clutch cover, oil dipstick cap, oil filter housing, cam cover end caps
- Custom knurled tappet covers
- Finned starter cover
- Cast and machined aluminum/Plexiglas ignition cover ? professionally painted to match
- New OEM Honda gaskets for everything replaced
- New stainless fasteners for everything replaced
- TC Bros Gold HD 530 Chain
- PBI HD 17T front sprocket
- PBI Aluminum 38T rear sprocket
- Relocated ignition switch
- UMI crankcase breather filter
- All yellow Tygon premium fuel hose for tank and carb bowl drains
- New OEM Honda top end gaskets, o-rings and seals from base gasket up
Ignition:
- PowerArc Optical Electronic Ignition
- Completely replaces everything including the mechanical points and advance
- PowerArc quad Ignition coil relocated behind side covers
- Custom carbon core wires
- NGK resistor caps
- NGK resistor plugs
Carbs:
- Rebuilt with OEM Honda o-rings and gaskets
- Rejetted mains with Keihin #105
- Adjusted air mixture screw
- Carb sync performed after each major modification
- Steel Dragon Performance billet aluminum velocity stacks with screens
- New OEM Honda Rubber boots to the manifolds
- New OEM Honda Manifold O-rings
- Powdercoated float bowls, top caps, velocity stacks, backing plate and manifolds
Exhaust:
- MotoGPWerks Stainless 4-1 exhaust
- Spring-mounted - a few minutes to have the entire system off
- Ceramic coated black billet head adapters and flanges
Lighting/Electrical:
- Complete custom serviceable wiring harness with Delphi WeatherPack connectors
- Bates 5.75? headlight with LED bulb
- RadiantZ Puckz LED taillights with custom waterjet and powdercoated mounting brackets
- RadiantZ brake module (adjustable, programmable brake light pulsing)
- RadiantZ LED license place frame
- Cognito Moto vertical license plate mount
- SpeedHut custom GPS Speedometer
- SpeedHut custom matching electronic tachometer
- Custom waterjet and powdercoated gauge plate
Suspension:
- Front Progressive Springs
- New Showa fork oil
- All Balls Racing front fork seals
- Polished fork bottom caps
- Billet aluminum fork top caps with new Honda o-rings - powdercoated
- Progressive 14" (+1") rear 5-way adjustable shocks
Brake/Clutch:
- Nissin Yamaha R1 14mm brake master cylinder
- Honda CBR250R clutch perch
- ASV C5 forged brake and clutch levers
- Slingshot Cycles stainless braided 1pc front brake line
- Powdercoated rotor
- Custom drilled and precision surface ground rotor
- New custom stainless steel caliper piston with new OEM Honda seal
- EBC front pads
- EBC rear shoes
- Powdercoated caliper, pivot arm, rotor, rear drum, axle spacers
- ATE Super Blue fluid
Wheels & Tires:
- Professionally painted black rims and hubs
- Zinc plated spokes
- Avon RoadRider 3.25x19 front & 4.00x18 rear tires
Controls:
- OURY Grips
- Dime City Cycles billet aluminum mirrors
- British customs billet mini brake fluid reservoir
Bodywork:
- Professionally prepped and painted gas tank, side covers and ignition cover
- Honda Fit Orange Burst Metallic
- Powdercoated gas tank cap lid
- Bobbed front fender
Miscellaneous:
- Motion Pro cables, lubed at all friction points:
- Push throttle cable
- Pull throttle cable
- Clutch cable
- Choke cable and knob
Posted the full specs. MotoGPWerks made both the alloy swingarm and the stainless exhaust. Chris (MotoGP) used to be a design engineer at Yoshimura, and has his own company now in California. His shop is across the street from the old CALFAB building, which he has acquired and started building repro CALFAB aluminum swingarms with some modern twists.
The exhaust is great, a little loud but some people have made their own baffles. My favorite part is that it is all spring connections so I can have the entire system off in a couple minutes.
The swingarms he makes are a work of art. He had a custom extrusion made for these, everything else is CNC machined and they are heat treated. Very nice quality piece!
- Chris C.
Nice Honda wing heel plates. That's cool. But yeah, info please. Is it yours? You built it?
Thanks! Yes it's mine, built it over the past couple years as my first bike. It was a complete rat nest when I bought it. She didn't run, had rigged up forward controls and brushed on bedliner over everything.
I designed the passenger peg mounts and had them waterjet out of aluminum at work, then sent them for powdercoat. Just a little touch but I like how they turned out. I love having a fab shop available, I cut quite a few parts for my bike there :grin:
I shit awesomeness
- Chris C.
I know Chris! Helped out at his shop a few times and so has another member here PunkBrad. I helped tear down the Ducati used in the Tron movie.
Chris has always got fun things going on over there.
I shit awesomeness
I think Chris still has my 1st issue of CustomFighters Mag at his shop.
- Chris C.
No way! That's pretty cool. I'm always drooling over the posts he shares about the early 90's race bikes.
I shit awesomeness
Shares posts? where? here?
1 - 15 of 15 Posts
