1 - 8 of 8 Posts
· Eff Tee Pee
k check this out guys. if i had gobs of money i didnt know what to do with...i might have a go at making a fighter out of one of these....
the new kawasaki concours
:confused: whats that you say??? im nuts??:nuts:
just look at the pics okay! heres the tech specs (some):
----------------------------------------------------------------------TECHNICAL SPECIFICATIONS
Engine
Type: Four-stroke, liquid-cooled, DOHC, four valve per cylinder, inline-four with VVT
Displacement: 1,352cc
Bore x stroke: 84.0 x 61.0mm
Maximum torque: TBD
Compression ratio: TBD
Fuel Injection: DFI
Ignition: TCBI with Digital Advance
Transmission
Type: Six speed
Final drive: Tetra-Lever shaft drive
Chassis
Front Tire: TBA
Rear Tire: TBA
Front suspension / wheel travel: Inverted, telescopic fork / TBA
Rear suspension / wheel travel: Tetra-Lever / TBA
Brakes, front: Dual floating petal discs with four-piston calipers
Brakes, rear: Single petal disc
· Eff Tee Pee
i guess i havent seen a naked zx14 but man that thing looks bad ass! its the zx14 motor in it with a lot of the cool little gadgets and what not. one big dif. is the shaft drive obviously.
· Perpetual Project
I've thought the same thing after looking at that second pic. Drag bars, a mini subframe with a dual exhaust coming out of it high - MT-01 style... you don't see many shaft drive fighters, it'd be a fun bike to build and turn heads with thats for sure:D
1 - 8 of 8 Posts
