1 - 20 of 22 Posts
Just welded up the top mounts for the subframe and wanted some opinions before I weld up the bottom mounts.
Do you guys think the tail is too high/tall or should I lower it an inch or two?
I like the height but can't decide if I should keep it the way it is or drop it an inch.
Its hard to tell with out the bike put together because you can't see the stance of the bike but I think it should like good there
Hack in a barn
I think the way I look at things like this is how angles are repeated, when angles and shapes are matched the bike flows well. In your case I like how from behind the steering neck where that angled piece of frame is matches the angles into the tank then going back that angle matches the tail angle.....
That's just how I look at "does this look good"...
But other things will depend. Like the swingarm and rear wheel could foul up that tail but at this point it looks spot on to me...
I understand what you're saying f'dup and if you keep the stock seat cover it will flow good but then again it all depends on how the bike looks up 2 wheels
Super Moderator
IMO, I'd drop the tip of the tail down until it was even with the top of the tank. But like said already, without wheels it's hard to imagine the stance.
Later, Doug
Reactions: yantosh and hrdy
I had it all together when I made the mounts and it looked good.I think it sits just a little too high so I dropped it an inch and think it sits perfect now.Thanks for the replies!
Here's a pic of how I'm gonna mount it today.
Hack in a barn
Looking good still man.
How's the length of it with the swingarm and wheels on?
I'm running an 04 Gsxr 750 swingarm on it.I cut over 6 inches off the subframe to make it match the swingarm length.Ill get some more pics up with the swingarm on it.
Oiler Boilereerer...er(s)
I'd lower it a tad, but yeah kinda hard to tell without a weighted stance.
G
Just my opinion but the tip of the tail needs to be level with the top of the tank when its on its wheels, this is what i did with one of mine with the same frame & tail imo it looked right & didn't bust my balls
a principle many of the best bikes follow :excellent:
Sick of being frozen
Nice bike! I would like to see more pics of it :rock:
I've got some random shots:
I could wheel it out of the garage and get some fresh shots if the weather would warm up.
Rich is off doing some stuff so we let his GSXR and Bandit sleep over with my bikes for the winter.
Reactions: Jaiked
1 - 20 of 22 Posts
