1 - 4 of 4 Posts
I bought these oil line adapters to use in place of the banjo fittings in the oil pan of my Bandit/GSXR build.
They didn't come with any o-rings or crush washer gaskets. Are they meant to be installed as is, or do I need to fit an o-ring or gasket? I have the correct size aluminum crush washers (off the banjo fittings) but once you slide them all the way down, the threads stop, and the diameter of the fitting gets smaller (like a shoulder, as visable in the above picture) and they flop around on there. Anyone that has experience with these please help. Thanks :)
1 - 4 of 4 Posts
