1 - 12 of 12 Posts
Found this on gixxer.com:
front calipers
gsxr 600 98-99
gsxr 750 88-99
gsxr1100 89-98
gsxr 1300 99-01
rf 900 r 94-97
tl 1000 s 97-01
tl 1000 r 98-01
bandit 1200 97-00
front rotors
gsxr 600 92-93
gsxr 750 88-95
gsxr 1100 89-98
rear rotor
rf 600 r 94-97
rf 900 r 94-97
sv 650 99-02
katana 750 98-05
gsxr 600 92-93
gsxr 750 88-95
gsxr 1100 89-98
gsxr 130099-05
bandit 1200 96-05
and this
http://gixxer.com/forums/showthread.php?t=104283&highlight=rear+rotor
Forks:
all 92-93 600, 88-95 750 and 89-98 1100 use the same bearings so the triples are a bolt on but the 92-93 600 and 93< 750 and 1100 have different steering stops so you have to work with that.
Late model forks work using the steering stem out of your triples and making a sleave for the late upper triple.
Swingarms:
all swingarms from 92-93 600's, 88-93 750's and 89-93 1100 have the same bearing size so are a direct swap. the 94-95 750 and 94-98 1100 arms work but you need to slip the bearing sleave and spacer out of your swingarm and replace the ones in the later arm.
Wheels:
All wheels interchange but you need the correct carrier.
92-93 600, 88-93 750 and 89-93 1100 are "twisted" spokes in 3.5 front and 5.5 rear but the 88-89 750 has a 4.5 rear.
94-95 750 and 94-98 1100 use the "straight" spoke wheels and these are lighter then the "twisted" spokes
Engines:
All swap. Air/Oil is Air /Oil be it 600, 750 or 1200 Bandit, 600, 750 or 1100 Katana, or 750 or 1100 GSXR.
Oil coolers:
"curved" (91-92 750/1100) coolers have the mounts in the same spots but the frame's lower mounts stick out from the frame farther on the 91-92 750/1100 but you can cut and space them out on your 88-90 750 and 89-90 1100. You need to get the hoses for the bike the cooler came from or even better swam to Earls UK fittings and braided lines.
Heads:
all can be swaped but cams are different and tooth count on the cma sprockes is different on the 88-89 750 and 750 Katana heads. Valve sizes are smaller on the 750 (except the 88-89 750) and there may be other differences.
Frames:
All swap but there are some differences in the rear subframe for the 91-92 750/1100 and the 1100 frame is 7lbs heaver then the 750.
Shocks:
All 92-93 600, 88-95 750 and 89-98 1100 shocks swap but the spring rates differ and the hose length varies.
Bodywork:
All lowers are the same from 88-92 750 and 89-92 1100
All the tanks from 88-92 750 and 89-92 1100 swap but te 1100 has a fuel level sender in the bottom rear so is slightly smaller in cap.
Mids from all 88-92 750 interchange
Mids from all 88-92 1100's interchange
Uppers from all 88-92 750 interchange but you need to use the correct mount 88-90 or 91-92.
Uppers from all 88-92 1100 interchange but you need to use the correct mount 88-90 or 91-92.
Uppers and mids can be swapped from 750 to 1100 but the holes in the mids will not line up and you still need the correct mount 88-90 or 91-92, the bars also have clearance issues.
· is not your fucking bro
the only thing i see is the 92 to 93 gsxr 600 is liquid cooled not air oil like it says. i dont know about the katana but the gsxr 600 abd rf 600 were always liquid cooled. and the early gsxr has straight spokes just like a bandit not twisted.
· Function IS Form
19 Z900, 88 Kat11
It's the message board where that icon is originally from.
In fact, most internet memes originated on 4chan in the past few years, like captioned cat pictures and motivational posters.
· Strassenkämpfer for life
Wheels:
...and 89-94 1100 are "twisted" spokes in 3.5 front and 5.5 rear...
...and 95-98 1100 use the "straight" spoke wheels...
Swingarms:
...and 95-98 1100 arms work but you need to slip the bearing...
...just did it (swingarm) this weekend on my '94 ;)
1 - 12 of 12 Posts
