1 - 20 of 30 Posts
Dux Brittania
New thread on refining my Beast Thing XS850 Triple Cafe.
While the XS Cafe Beast is sharper cosmetically than when my project began last yr. the bike could use
some updates / improvements to it's safety, performance & handling. :knucks:
Installing sticky Bridgestone Battlax BT45 V-rated 240kph tires.
Huge improvement over the hard old Kendas it wore.
Super deal for only $201 pair / shipped.
Various cosmetic bits to give bike that warm cafe-racer look.
32 yr old switchgear was trashed ... time for new from MikesXS :thumbsup:
Other updates to follow...
Dux Brittania
Drilled train-like peg brackets will have to suffice until the vicar lets loose with more DW $.
That means fabbing me own brackets w/ new shop tools.
Got bit off-center on one hole - once chamfered, it's hard to see. :CK187:
RR'ing the wire harness awaits ...
Pinstriper4fun
Looks sharp. Keep the updates comin.
fighter transplant in NC
do something about the diamond plate please. otherwise I think you're on the right track
Dux Brittania
As Larry sez; "May God bless the Pygmies in New Guinea ..."
for they have sent me a set of new Battlax V tires today. :letsride:
Been inhaling that fresh rubber aroma while replacing PO's toasted wire harness :lotsocoffee:
Along w/ new bearings for factory fresh steering.
No worries; Tis not real diamond plate (.035" fake stuff)
-- th' replacement .025 flat alumin. sheet getting on dere soon. :rock: :rock: :rock:
Dux Brittania
Nice new supple BT45 V tires installed on rims today. :thumbsup:
Along w/ polished brake calipers, system gets Hi-Perf. DOT 5 Silicone fluid change. :rock:
Dux Brittania
Finally a calm day. Geez I actually did some work! :shocker:
Installed shiny new clutch perch / lever.
Fabbed an inner fender from the "fake" aluminum diamond plate (.035")
stuff works great as a bulkhead.
Polished the stock alum. rear brake carrier / bracket & re-installed.
Pics will follow.
Dux Brittania
Caliper paint didn't look right. Polished rear brake helps sets cafe theme.
RUST REMOVER
That looks sweet, I need to do my forks and maybe my hubs
Dux Brittania
GS - thanks bro.
I'm doing th' pimp work, polishing triple tree, front calipers and forks.
Takes a lot / gives a lot back. :knucks:
Dux Brittania
More work done - polishing top clamp = bling
Before:
After:
Installing new Stem Bearings...
Upper steering bearing was almost dry, lower bearing was 100%.
Bling-ing the forks
New fork rubber /boots
Next: Fabricating DIY headlight mount brackets. :CK187:
RUST REMOVER
Awesome.
Dux Brittania
Did more work! .... :lotsocoffee:
Almost ready to re-assemble front end: rough mock up.
Fork legs cleaned & polished, HL ears fabricated. .......... :yamaha:
Ooh it shines ... time for a break....... :lotsocoffee:
.:knucks:
Dux Brittania
Legit goon
Looking real clean mate!
Reactions: Crom_child
RUST REMOVER
Looking good, I did that same fuse block mod on my xs. Keep up the good work!
1 - 20 of 30 Posts
