1 - 6 of 6 Posts
Everything is simple...
Discussion Starter #1
Here's some info, specifically about motorcycles, from the highway traffic act for Ontario, Canada.
The following deals mainly with the regulations for lights, helmets, exhaust, etc.
Let's begin...
:shockerknucks:
Lamps
Lamps required on all motor vehicles except motorcycles
62. (1) When on a highway at any time from one-half hour before sunset to one-half hour after sunrise and at any other time when, due to insufficient light or unfavourable atmospheric conditions, persons and vehicles on the highway are not clearly discernible at a distance of 150 metres or less, every motor vehicle other than a motorcycle shall carry three lighted lamps in a conspicuous position, one on each side of the front of the vehicle which shall display a white or amber light only, and one on the rear of the vehicle which shall display a red light only. R.S.O. 1990, c. H.8, s. 62 (1).
Lamps required on motorcycles
(2) Subject to subsection (3), when on a highway at any time every motorcycle shall carry two lighted lamps in a conspicuous position, one on the front of the vehicle which shall display a white light only, and one on the rear of the vehicle which shall display a red light only. R.S.O. 1990, c. H.8, s. 62 (2).
Idem
(3) When on a highway at any time every motorcycle with a side car shall carry a lighted lamp in a conspicuous position on each side of the front of the vehicle which lamps shall display a white or amber light only and a lighted lamp on the rear of the vehicle which shall display a red light only. R.S.O. 1990, c. H.8, s. 62 (3).
Light requirement
(4) Any lamp required under subsection (1), (2) or (3) shall, when lighted, be clearly visible at a distance of at least 150 metres from the front or rear, as the case may be. R.S.O. 1990, c. H.8, s. 62 (4).
Exception
(5) Despite subsections (2) and (3), where a motorcycle that was manufactured prior to the 1st day of January, 1970 is operated on a highway, the lighted lamps required under subsections (2) and (3) shall be required only during the period from one-half hour before sunset to one-half hour after sunrise, or at any other time when, due to insufficient light or unfavourable atmospheric conditions, persons and vehicles on the highway are not clearly discernible at a distance of 150 metres or less. R.S.O. 1990, c. H.8, s. 62 (5).
Strength of lamps
(6) Lamps on the front of a motor vehicle shall be so constructed, located, arranged and adjusted that when lighted as required by subsections (1), (2) and (3) they produce under normal atmospheric conditions and on a level road a driving light sufficient to render clearly discernible to the operator of the motor vehicle any person or vehicle on the highway within a distance of 110 metres ahead of the motor vehicle. R.S.O. 1990, c. H.8, s. 62 (6).
Rear lamps to illuminate number plate
(19) The lamp on the rear of a motor vehicle or trailer shall be of at least three candela and shall be so placed that it will, at any time from one-half hour before sunset to one-half hour after sunrise and at any other time when, due to insufficient light or unfavourable atmospheric conditions, persons and vehicles on the highway are not clearly discernible at a distance of 150 metres or less, illuminate the numbers on the number plate, or, if provision is made on the number plate or on any attachment furnished or required by the Ministry for affixing the lamp, it shall be affixed in the position or space provided, and the lamp shall face to the rear and reflect on the number plate a white light only. R.S.O. 1990, c. H.8, s. 62 (19).
Brakes
Brakes, two systems required
Motorcycles, etc.
(2) Every motorcycle, motor-assisted bicycle or power-assisted bicycle when being driven on a highway shall be equipped with at least two braking systems, each with a separate means of application, with one effective on the front wheel and one effective on the rear wheel. 2009, c. 5, s. 29 (1).
Odometers
(5) Every motor vehicle other than a motorcycle shall be equipped with an odometer in good working order. R.S.O. 1990, c. H.8, s. 66 (5).
Muffler
75. (1) Every motor vehicle or motor assisted bicycle shall be equipped with a muffler in good working order and in constant operation to prevent excessive or unusual noise and excessive smoke, and no person shall use a muffler cut-out, straight exhaust, gutted muffler, hollywood muffler, by-pass or similar device upon a motor vehicle or motor assisted bicycle. R.S.O. 1990, c. H.8, s. 75 (1).
Motorcyclists to wear helmet
104. (1) No person shall ride on or operate a motorcycle or motor assisted bicycle on a highway unless the person is wearing a helmet that complies with the regulations and the chin strap of the helmet is securely fastened under the chin. R.S.O. 1990, c. H.8, s. 104 (1).
Turn signals
Requirements for signalling device
(6) A mechanical or electrical signal device shall clearly indicate the intention to turn, shall be visible and understandable during day-time and night-time from the front and from the rear of the vehicle for a distance of 30 metres, and shall be self-illuminated when used at any time from one-half hour after sunset to one-half hour before sunrise. R.S.O. 1990, c. H.8, s. 142 (6).
Stop signalling device
(b) by means of a stop lamp or lamps on the rear of the vehicle which shall emit a red or amber light and which shall be actuated upon application of the service or foot brake and which may or may not be incorporated with one or more rear lamps. R.S.O. 1990, c. H.8, s. 142 (8).
Racing, stunts, etc., prohibited
172. (1) No person shall drive a motor vehicle on a highway in a race or contest, while performing a stunt or on a bet or wager. 2007, c. 13, s. 21.
Offence
(2) Every person who contravenes subsection (1) is guilty of an offence and on conviction is liable to a fine of not less than $2,000 and not more than $10,000 or to imprisonment for a term of not more than six months, or to both, and in addition his or her driver’s licence may be suspended,
(a) on a first conviction under this section, for not more than two years; or
(b) on a subsequent conviction under this section, for not more than 10 years. 2007, c. 13, s. 21.
that's about it for Ontario. 'Course, I might have missed some here and there, so this is in no way a complete list. Use it to do some reasearch, or to point you in the right direction.
:thumbsup:
Sympul
Rich
Holly shit
on conviction is liable to a fine of not less than $2,000 and not more than $10,000 or to imprisonment for a term of not more than six months, or to both, and in addition his or her driver’s licence may be suspended,:nuts:
So where in the US are u moving too? :LolLolLolLol: Sounds like they got you under there thumb FTP! ....:cops:
Discussion Starter #4
yea, they've busted down hard on racers and stunters. There's been a bunch of deaths of whole families, but the racer / stunter walked away. (Mostly it's been car racers, but there's been a few bikes involved.)
So... they punish everyone.
yay!!
:shocker:
I wonder what they think is a "Hollywood" muffler? Aftermarket maybe?
hollywood muffler = fake muffler. just a shell with out any guts.
1 - 6 of 6 Posts
