1 - 2 of 2 Posts
Please email. Main part list. Prices OBO. Pickup in N. Austin, or can deliver at cost. Maybe other unlisted parts. Lots of pics of all parts available. Please email to inquire......
Valve Cover - $25
BallistiGrip Seat - $100.00
M4 Race Exhaust and plug - $350
Head to Frame Mount - $15.00
CDI and Wire Harness - $75.00
Carbon Fiber FiberWorks Skid plate and hardware - $60.00
Stock water pump gaurd metal - $15
Radiators and Guards - $150.00
Hot Cams Stage 1 intake and Exhaust w/ new OEM chain - $235.00
Carb intake boot - $15.00
GYTR Frame guards both sides - $65.00
Swing Arm Axle - $20
Built Bottom End - Hot Rods #621 Crank and rods, SFB case covers, SFB 13oz flywheel weight and spacer, Vertex 95mm high compression piston, all new waterpump, impellar shaft, bearings, new steel mesh oil filter, seals. - $1100
Air box - $50.00
Rear brake, carbon fiber rotor guard - $75
IMS Pegs - Pro Series - $60.00
Front brake assembly for oversized rotor - $130.00
Front Axle - $20.00
Talon Hubs, Excel Takasago Rims, Gold retainers, SS spokes, oversized from floating disk, 49T sprocket on rear. $1100.00
Clutch perch, lever, cable - $30
Universal Triple, stem, bearings - Possible not stock offset - $200.00
Front Forks - Race tech springs, good fluid, fully adjustable - $225.00
Frame - Perfect frame, oil lines, clean title, with links still attached.- $225.00
Plastic kit - Lots of parts, numbers and not, clear, new UFO - $120.00
1 - 2 of 2 Posts
