1 - 4 of 4 Posts
BLACK BELT
I need a small stainless adapter to mount an OEM knob onto a Pingel petcock.
It could be made from a 5/16 inch stainless rod. (The O.D. is 5/16 inch.)
The 5/16 rod needs to be turned down to 7mm on one side. The larger hole is an M3 thread for the OEM knob. There is a bore drilled in the larger side to insert the petcock rod. A 1/16 inch spring pin fits in the smaller hole to fix the adapter to the rod. The total length is around 26mm.
I have completed drawings with all the numbers.
Sebspeed .
1 - 4 of 4 Posts
