1 - 19 of 19 Posts
· Ebay PosterChild
so i was gonna do this a long time ago but today since i f***Ing busted my ass end of my bike whilst sanding i figure sure why not :rock:
start of you need the following:
-gloves
-mask
-tape*not duct tape well you can but your an idiot if you do*
-heatgun
-drywall tape
-plastic cleaner
-plastic bondo
-primer
-paint
-cleaner
-epoxy*fusor 141 with fusor gun*
-plastic adhesion compound*fusor 602*
-paper towel
use the tape to hold the pieces together its just an extra hand thats all so its dont move while you work with it
then apply the fusor 602 addhesion spray its just like a glue that hold the drywall mesh/tape in place
now apply the epoxy compound use what ever kind you want but i have the type autobody shops have and is a 2 stage epozy and the plastic will break before the epozy if applied corectly
hit the epozy with heat *mine requires heat to harden* but make sure not to hit it too long :LolLolLolLol: or it will melt the plastic.
· Ebay PosterChild
next step use bondo i got plastic bondo since it flex's 30% more then regular bondo and is the same price as regular bondo
spead it over the outside surface and make sure it gets in all the cracks
now i never accually finished since its taking forever to dry but all you do from here is sand it smooth and if you wish to apply more bondo do so if not you prime the piece here you use the blow gun and blow off most of the dust but dont point it too close then get the plastic cleaner or just cleaner and wipe the whole piece down and dry it using the paper tower then apply your primer i just use regular Agriculture primer
then once its dry either sand it smooth or whatever you want since its a fighter i didn't care since im sure ill scuff the shit out of this bike and i just went from prime to paint in 20 minutes :nuts:
voila clear then let dry and your done :rock:
· Eff Tee Pee
i weld plastic all the time. zipties will work. butyou can get a better plastic that comes in slices for the process.
tool isnt all that expensive and more than worth it, esp if you stunt.
i've fixed and sold over $500 worth of plastics that woulda been junk otherwise.
:metal:
· hack
or you can also buy the plastics off other members with the same bike for cheap.... (jesse, I have that other tail fairing in good shape if you need it)
· avatar gangsta
I got this. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41592
I have only used it once, and pretty much suck with it. Guess I need practice. I actually have a set of EX500 plastic I have to rebuild. I have to make up some pieces and then weld them and the larger cracks up. I then plan to fiber glass the bigger holes, and use spot putty the fill the smallers ones.
I have actually used a soldering gun to fix small cracks in the past. Works better if you use an extra piece of bodywork to lay over it, then you can melt it all the way around.
Looked like your job came out great! I need a paint booth like that, with racks and stuff!! Hell, I wish I could just keep the bugs out of my paint jobs!!
· Active Member
This is the plastic welder I use: Ebay Link. It's a pretty decent kit as a whole and even comes with a How-to dvd. Similar to welding metal, if you take your time and practice on scrap plastic similar to what you need to repair (ABS), you can make some excellent repairs. Also, here is a little "How-To" on plastic welding: CycleForums Linky.
· GURU
Holy shit! I just found this thread. Thanks a bunch guys this is gonna save me a ton!!!
Where can I find some abs core rods to fill the cracks with? Also, could someone eleborate on how th smooth the surface down properly after it hardens? Thanks!!!!!!!
1 - 19 of 19 Posts
