1 - 8 of 8 Posts
· British Bloke in Canada
Im Kinda impulsive I tend to jump in to things and often enough things work out, though my bike now sounds Great, and seems a little torqueyer in the bottom end
· Eff Tee Pee
you did a good job on the pipe. how exactly did you do that??
have to send ya some stickers if you wanna do a write up. :D
i have a two bros for my 929 that id like to cut in about half. :LolLolLolLol:
also i think it would look even better if you ran it like a highmount up next to the tail... :twocents:
· Eff Tee Pee
SNGPerformance said:
I still think it would look better with the strap off the badge.
you think he should put it down by the bottom of the pipe??
· Eff Tee Pee
ab420 said:
I think it's perfect where it is... you just need to alter it a bit....
so it says YO MAMA!!!!!
:LolLolLolLol:
thats not a bad idea either! :cfrocks:
I should of took some pictures of taking it apart and then rebuilding it, but it wasnt something I had planned it was a spur of the moment, Midnight boredom kinda effort, but basicly it goes something like this,
remove pipe of bike
drill all rivets out and totaly disasemble
measure 350 mm from the end you wanna keep
mark with scribe
then place masking tape round the whole circumferance of pipe
with a grinder, with a thin cutting disc, cut to the edge of the tape,
DOnt try to cut it with a saw, you will bend the can out of shape, cause the titanium is a bastard to cut,
the interior baffle needs it wadding removed (wear gloves and a Mask)....Cough ( its ferking orrible stuff )
then cut down internal baffle to match lengh, baffle can only be cut at one end.
the exterior of muffler needs to be deburred and filed
the bolt on end needs to be gently tapped back inside ( large rubber Hammer ) the internal metal baffle should allready be a part of the bolt on end,
I then instead of wrapping the internal baffle I pushed as much of the Fibre back in to the pipe as I could, arround the baffle
I wrapped the internal baffle that was apart of the end of the can, and wired the fibre on to it with welding wire,
I then tapped the end of the can ( large rubber hammer ) back in to position
I re-revited the muffler back together, and bolted back on to the bike,
It isnt that loud, it seems to have given me more midrange torque
and is a little fluffy just arround tick over, that isnt a problem, it actualy sounds really nice, I would Describe it as Throuty, Ill take some VIDEO and post a few seconds for you to here it soon.
1 - 8 of 8 Posts
