1 - 20 of 44 Posts
YamahaHooligan
Well after nearly 2 years of not accomplishing anything other then collecting parts im finally getting this old bastards back on the move!
Rambo is a totally different direction from my "minimalist" build. Complete overhaul. I've grown in taste and skill since I first joined here, so hopefully that will be reflected in this time around...
Started with
Since my time and resources are limited, I have commissioned some of the machining out to a buddy to get the chassis into a roller again.
Here's what I have:
89' Yamaha FZR600 frame and motor
03' Suzuki GSXR 750 Forks (thank you again UF!!)
??' YZF600 swingarm
02' Yamaha R6 rear wheel/caliper
??' Suzuki SRAD front wheel
95' Kawasaki ZX7 front calipers
83' Suzuki GS1100 tail fairing
02' Yamaha R6 header
07' Yamaha R6 shock
Assorted parts from Green Machine Customs...
It left the house looking like this
More in a week or so once I have the roller back!
YamahaHooligan
I know UF! Got sick of seeing it hanging in the basement.
As far as cafe look, not really the direction im going. The task cover is actually from an FZR400. Nicer lines/angles then the 600.
Im going to slot the tank in the front to resemble the Yamaha M1 tank... not nearly as cool, but hey!
Should have some time tomorrow to setup my drill press and milling table to start skeletizing the front sprocket cover
YamahaHooligan
So spent lots of time doing domestic horseiron around the house today. Did get to pick this addition to the shed up though
Spent time filling that, and figuring out which tools stayed in the track box...
Pulled the ZX7 and little 2stroke out for my son too
.. good times had by all...just no work done on sprocket cover
Hack in a barn
URL="http://www.customfighters.com/forums/showthread.php?p=1818097#post1818097"]http://www.customfighters.com/forums/showthread.php?p=1818097#post1818097[/URL]
When you use the insert link thing in the post, change the stuff in red to what you want the link that you click to say...
EDIT: remember too on the controls harleys have 1" bars, I've made spacers to run 1" controls on 7/8" bars but it's not really a good option,,,
YamahaHooligan
So still waiting on the bike to get back from the shop...do started working on my shop
After modifying the Harbor Freight 20 ton press so that it actually worked did this just cuz
Have to set up my drill press and milling rig...its ghetto but works...i guess
Starting a new job on the 7th, where I will be properly trained in welding, so excited for that. Machinist buddy said should be soon on the rolling rendition of the frame
Stay tuned
YamahaHooligan
Well here's an actual update!
Most of the rolling parts have been sorted. Waiting to get it back from the shop still.
Recently purchased a Mikuni vacuum fuel pump, not sure if ill use it or how it even works, but its a good back up when the electric one shits the bed.
Also picked up an Ignitech cdi
I just need a computer now so I can use the thing.....
Debating using the gs1100E tail still or using a cbr tail...I have an r6 (1st gen) tail at my disposal , but I feel like that's been done
YamahaHooligan
So I'm looking for front rotors. I was thinking of doing these, but not sure about buying cheap rotors?
In other news the bike should be coming home next week. I' def going with the 05 cbr1000rr tail section. Ill have to make an undertail since the honda has an undertail exhaust.
1 - 20 of 44 Posts
