Hello there!
The bike is 90' gsx600f. I have an 91' gsxr swing arm on it, and I want to put gsxr 750 K9 rear shock which is 10mm longer then the original 300mm shock. it's a tight fit between the upper mount and the rocker but I got it in. but now I can't make those arms that connects the rocker with the swing arm fit, it misses the hole only by a bit and if I compress the shock it will definitely align but then when it will be free those links will touch the swing arm. when the motor will be on the bike it probably wont touch when it sits but my concern is that i'll hit a bump on the road and it will slam against the swing arm and cause a damage.
should I grind the swing arm to make some space over there?
