I am rebuilding the forks that I am swapping onto my bandit before the swap and I was wondering if I should upgrade the spring while I'm inside of them and is there anything else I should upgrade internally while I have them apart.
A spring swap certainly won't hurt. But I say unless you're doing track days or super aggressive riding the stock internals are fine. I bumped up to RaceTech 0.95kg/mm springs in the same front end when I swapped it into my '89 Gsxr.
I won't be doing track days any time soon or super aggressive riding. I plan on getting some .95 springs. But I'll just keep the stock internals. Thank you for the input.
I just did the seals and bought the oil. I need the springs still. I am also waiting on my oil level tool. If you need a fork seal driver for 41mm forks you can certainly use mine
Agree with above, new springs and good oil in your weight of choice will do wonders. For a fork seal driver, I've used PVC pipe of the right size, worked perfectly. Of course, a proper seal driver would be nice also.
The springs are on their way. I bought a proper seal driver and that made quick work of the seals once I secured them in a crafts man workmate table to prevent the sleeve from sliding.
I'm also debating new springs for my 1992 gsxr 600. I bought a 2006 gsxr rear shock because the stock rear shock damper seems pretty useless and it's non rebuildable, but I'm reluctant to swap it in without also increasing the front spring rate. It seems like they should work together and be close in spring rate.
I'm trying to find out if I can use springs from a later model gsxr in my forks, but I can't find any length/diameter information to see if they will fit.
What did I do wrong?! So these form were rebuilt in ~march and I finally got around to swapping them on to the bandit, but the rebound seems extremely slow. When off the bike: I can compress them and the rebound is pretty slow. When on the bike with weight of bike resting on them: if I compress them rebound is almost non existent. It comes up a little but not all the way. Do you think it could be the valve or maybe the new springs I put in the forks? Please help. I have half a mind to take them to a shop to do a proper rebuild
Related Threads
1.6M posts
40.4K members
Since 2006
