1 - 20 of 27 Posts
V four honda whore
Discussion Starter #1
In idea i have several, but for now gonna focus on one maybe another in a while
so as some of you might know my good friend Matti got a free kx65 with a dead engine for electric bycicle project. that failed for him. But i had this urge to get a minisupermoto for a while. so he offered me his, because he was going to junk it anyway.
so i got it brought to Latvia by a "relative" tucked it in my car on our visit
did a quick assembly one evening(i know the forks are wrong way in, it's already fixed
since the lump was bad one and new cylinder kit is 400eur, i decided to crap that shit ad get something cheap to fit in. so after an ebay browsing i stumbled upon 40eur EBE engine from bultaco astro(derbi senda, i think some aprilia, well it's popular)
since they come as 200-300eur in decent state i took a gamble, that i might lost
will try to drill this out
as for head, well two head studs came out one was already snapped and one is quite stuck
also the piston doesnt move, so it looks i will need a new crank, or iļl give repressing a bearing one this one a go
took some fight to get it off
head has a crack in it aswell
clutch side looks good tho
good thing about engine is...
they're cheap for an engine
new crank starts around 50euros, cylinders has a lot of aftermarket, with bifferent crank can be made up to 110cc( and thats two stroke we are talking about)
about the chassis, it's okey, plastics needs to be sprayed, one of fork legs leaks, missing front numberplate, steering clamp.
my aim? to get it ridable within less than year, so i can take it to Smash next year. but i also want to take VF build too, so as always i have bitten more than i can chew
Reactions: shinyribs
Super Moderator
Been digging through the garage some more, got an airbox I have no vehicle for so it`s most probly from the kawi... There was some other bit too I cannot remember off the top of my head that might also belong to the bike, it was plastic but no idea what it was... I did give you the rad grill at smash didn`t I?
V four honda whore
Discussion Starter #6
Yeah, that grill just appeared in my tent
lb/hp is what it's about!
I just realized how high this bike sits. Are you gonna need to lower it for the swingarm to not drag on the chain?
My YZ80 was the same way but as soon as I sat on it the angle became much more reasonable. I'd imagine the same will happen to this.
V four honda whore
Discussion Starter #9
yeah, the suspension is soft as baby poop
When I saw the post title... It made me think of high school gym locker room teasing... not about me of course.:oops:
V four honda whore
Discussion Starter #11
so... first of all big thank you to Kimmo for donating a lump. Derbi EBE unit with 85cc kit
tried to fit it
kinda fits, except for few isues
a bit heavy on one side, if i want the chain to be aligned. but it will work
water channel for head, will have to be modded in order for cooling to be working
this is already bent for clearance, but yes, this too
and yes, this is where the fun begins
so in order to have a working pipe, i need to angle it straight bend right out of head and turn it around frame. since there's no place on right side of bike, and originally derbi engines has pipe going on the left, that was only logical solution|
so i started to look around for possible pipes. the original kx65 was goingon the right side *this is also a bit on an issue, since i will have to relocate radiator from left to right.
looked around for a cheap pipe options, beside i was looking for tuned pipe, since engine isnt stock. kinda got a great deal for pipe with bashed first part of pipe, i needed to redo anyway, but the guy changed his mind. so i found leo vince 70+ cc pipe with muffler for 30eur, had a dent though.
dent was hard to remove without welding, but... it didnt quite fit the way i thought to fit it. kx pipes other half kinda fitted, but that meant i had to rebuild first part and i have no idea about lenght and diameter it has
Reactions: Kimmo57
V four honda whore
Discussion Starter #12
so in the spirit of CUSTOMFIGHTERS.com and the fact, that i like to learn and try new things, when it comes around bikes, i decided to take measurements of leo vince pipe, work around web program of cone bending and look what i can do
started with paper model
at this point i unerstood, that paper is flimsy and i should have some issues, but i am stuborn and decided to try it anyway
this is the part i made a small mistake, but later about that
we have a car repair shop next to my work, and i asked some steel sheet, i think it was 1mm thick
layed out templates and marked around them
rough angle grinder cuts
flap disc sanded
hand bent cones against piece of pipes i had at garage
loaded bike up in Tofu and headed for my dads work, where i have acces to MIG welder. keep in mind i'm not too good with it for the rest of part you read. but PRACTICE MAKES PERFECT
yes i grinded the seams
since i bent them by hand they werent exactly round, so i had to work some magic around them with vices and some bending, a bit of hammering
anyway this is how far i ended up doing
so there's where my previous mistake comes to play, i have somehow missed making of two cones i had on paper model. will try to make them this week and weld shortly after test fiting them on bike again.
was the making of pipe fun? yes
challenging? yes
fun? kinda
hard? making cones took me 5 hours of almost non stop, welding was around 7h i think, knda lost track of that, because i also had to weld lower engine mounts before doing pipe.
will i do it again? possibly i have mbx80 i want to make into a road legal mini
V four honda whore
Discussion Starter #14
Nice work on the exhaust! It looks like a lot of the pictures are not showing up. I see a circle with a horizontal line in the middle of it.
I used google drive as a source. Works from PC, messes up from tapatalk with few... If anyone else encounters this, i'll try to reupload them somewhere else
V four honda whore
Discussion Starter #16
Try it now
CAPTAIN AWESOME®
Making your own chamber?? That's awesome right there!
Good luck with the mini. Hit me up for any mini sumo knowledge I may have left
V four honda whore
Discussion Starter #20
Made new cardboard cone mockup to see how it fits. Because old and original one was in a bad angle
Then cut it out and welded together
As for muffler. The slip on part snuck easy on an old bars that i used to have on vfr and bent after a crash in track. So yes i have a steering bad as exhaust. Made a slip on part out of sheet metal on chamber side. Have to fab up some brackets to hold the exhaust.
Like how it looks. Now up to fit radiator. Make brackets for side fairings. Clutch cable, cooling, ignition and carb. Wheels
1 - 20 of 27 Posts
