21 - 32 of 32 Posts
V four honda whore
Discussion Starter · #24 ·
@Mattson sent me some carbs, he claimed it as birthday gift. So thanks to him... after being dissapointed in bros i was looking for stuff to do around shed, so i dont feel so bad. took the reeds and intake manifold off ebay lump. of course it wont fit, because carb is 28mm IIRC and original is small. looks like i might try to make one myself from steel i have around
while i was at working on ebay lump. tried to get the cylinder off. it wasnt an easy task, also it already was damaged, so i went full on ballistic, with heat, angle grinder and hammer.
also it finally paid off to have welder at shed, and i could extract the bolt that was PITA from beginning
oh also, i took ylinder off my MBX80... looks like i need to take it for milling and hooning one size bigger
Reactions: yantosh
V four honda whore
Discussion Starter · #25 ·
bought a lighty used cylinder from euro3 model. was told it fits, also was told it's airsal. but it's stock one, aluminium though. but hey 10euros
also, cut the mount bolts that are stuck in casings, so i can split the engine. heat and hit them out with less resistance from lenght
if ya squint it's mint
oh forgot pics of cylinder
this is the reason why it was cheap. welding a nut to it and screw it out doesnt bother me much
Reactions: Mattson
V four honda whore
Discussion Starter · #26 ·
bought this wonderful tool
so i can do this
the bolts even started to bend... it took some heating aswell. one bearing even cracked and around 30% of outer side fell off. but in the end i did it
now i need to find time to clean it, press the pin out. and head after new bearings
also managed to heat and hit out one of 6 axle halves that are left after i cut them so i can split the engine cases
and all of this, becaus i had nothing to do whule i wait for pulse generators for Bros
V four honda whore
Discussion Starter · #27 ·
been a while... so i have carb for it, and daihatsu heater core for cooling, that will be mounted where the headlights usually are, because there's no place for anything due to exhaust. but now i have another idea, but we'll see about that. i also picked up bends and tube to start intake manifold (again not enough space).
but i picked up chinese ktm sx50 ignition from post office. mocked it up. seems that i'll need to mod the inner taper for derbi size a bit. and i started the journey to get an adaptor plate made
Original ignition i had
"KTM" unit
img]https://i.imgur.com/rRsfbbx.png[/img]
3 model of adaptor plate
I'm about to start building a secret tard project... I'll show you mine if you show me yours
MOAR PICS
I'm about to jump into adapting a different stator myself for the project weirdly enough.
V four honda whore
Discussion Starter · #29 ·
MOAR PICS
i'll have to take few, since i bought another engine and street legal 07 peugeot xp6 frame with plastics, need wheels now
21 - 32 of 32 Posts
