so due to lack of funds and distractions last month i finally got to ride this bike. it went to inspection and failed, need to fix turn lights this week and reinspect it.
anyway, decided to change the oil. ended up with messed up bolt thread in oil pan. had to remove pan and rethread the hole for bigger plug.
then after some riding around, i had to take my brother home. well... he is not the smallest of guys so after right turn exhust scraping i got sick of that issue, and decided it is time for me to redo the pipes. so that's what i did last friday evening. here is the pics
this is before, as you can see it sits too low and makes it hard to lean bike on that side, therefore i'm affraid to lean it on that side
i cut down previous manifold into pieces and flipped Y pieces i had, so it is going up (iļl try to explain as i dont have pics. now the upper pipe is straight and lower makes bend(two pipes per side)) you can see it in picture
other side with bend for can
finished result
but to be honest i want a different pipe now
some shitty dark pic since it got super dark at the time i got done
also since Ildze is not really keen on riding with me i'm kinda considering maybe i should put on a different tail on bike.
gonna have to try photoshop to look how does it fits bike in lines together
