1 - 7 of 7 Posts
I am from the uk were it rains a lots and the old srad is ridden loads. Old cover had holes in it so took off old cover and squeezed out most of the water its sitting in the house just know.
i got some water proof fabric off line cheap to make a new cover need to re glue the foam to the plastic
If you're house has central air conditioning prop it up in front of ( but not blocking) the return air grill. That oughta be able to dry it out while you're gone for work one day.
Or run through the laundry dryer on low heat. Maybe put it in a pillow case first if you're worried about it dropping bits of foam.
I have left it in front of a heat to dry it the best i can before i can fine some spry glue and stick it back down to the plastic base
1 - 7 of 7 Posts
