1 - 9 of 9 Posts
lɐʇuǝɯᴉɹǝdx&#4
Just got a really ratty spare seat for the FJ, with plans of using the pan to build up a solo seat with custom ergo (can't slide back far enough on the stock) and maybe a small carry platform.
What do people suggest I do for foam? Would high density upholstery work, or is that to soft? I've heard suggestions of building up layers of yoga / camping mats with contact adhesive? What about those EVA floor mats, the ones with the interlocking edges made for kids rooms and work benches? What I really want is something with minimal water holding ability, fairly firm but not rock hard, that is at least an inch thick.
Feckin Eejit!
Ive seen all of what you've mentioned used.
Have you used a corbin? They're primarily higher density.
http://corbin.com/faq.shtml
They mention "most stock motorcycle seats use a foam density of 3-4 pounds" and "On average, Corbin foam is used at a density of approximately 7 pounds"
Thats lbs/cu ft iirc.
The problem I ran into when trying to get a gauge on EVA foam is none of the folks that sell it actually say what density formula they're using. You can get the stuff from 2 to like 25 density.
I ended up with a plan to cannibalize my corbin so I didn't have to worry about any of this :p
hate us cuz they ainus
I used some hydro-turf
Its really not as bad as it looks. But I don't really spend extended periods of time on it either. If you want something a little more soft and pillowy I have a mk1 bandit seat I can pull the foam from if you think it'll be a large enough piece for you to shape how you want it
Isn't as dumb as he seems
I have 2/3rds of a yoga mat you can have for the price of shipping... One side has a ridged pattern, though, so while you could interlock the layers with glue and pressure, I'm not sure how well it would hold up to heat and movement.
HipsterKillerGarage
What you want is a higher density closed cell foam (rebond) if you're planning to cover it. Rebond doesn't absorb water like regular open cell.
Otherwise, get some neoprene and some dragon skin and shape a piece. Check out online kayak suppliers for a piece. You can get a 12x12x3 piece for cheap. It's the same stuff people sell on ebay as "race foam" for a hefty profit.
1 - 9 of 9 Posts
