Hi new to the forum. Im in the middle of changing the front end of my 2001 yamaha fzs600. Ive bought and wired up a koso rx2n+ but im struggling with the settings. Ove wired the speedo sensor wires direct to the speed pick up on the front wheel(5v signal and earth). The koso is asking for diameter and number of pick up points. How do i work out the pulses per revolution please and the mm
Tach, I have wired this into the rpm wire on the origional dash. Am I right in thinking this should be set to 4 stroke 2 pistons and finally fuel gauge. What settings do i need to set it at to get accurate readings. On the origional cluster its showing half a tank but the koso is showing full tank. Sorry for all the questions but instructions arent very clear. Thanks,
