1 - 8 of 8 Posts
· Eff Tee Pee
SOMEBODY, QUICK..GET THE FAIRINGS OFF HER..SHE NEEDS AIR!
· Newbie
she needs more than air, iam running into problems allready. the bolts that are holding the headers on are rusted in the head i got one out after heating it and striped one. does anyone know if these would fit http://cgi.ebay.com/ebaymotors/suzu...017QQitemZ270063275434QQrdZ1QQsspagenameZWDVW the reason iam asking is i need new tires,roters and pads for the front and rear that would cost me atleast 300 dollars. thanx for your help. sorry english is my second language.
· the mad doctor
i believe those rims will fit. the only thing you may have to do is make some spacers to center the rear rim in the swingarm, but that's not too hard. there's a dimensions sheet on www.oldskoolsuzuki.info, for some reason it won't let me link diectly to it. most of the older suzuki's have the same sized axles. i used those exact same rims on an 87 gsxr. i just had to use the original rear brake disk on the new rim, and space the rear wheel correctly, and they went right in. the kat's and old gsxr's share ALOT of parts, and swapping them around is quite easy.
· Bush pilot
Bike looks good, a good starting point. As for the header bolts that sucks and theres not much for easy ways out. The rims will most likely work, with spacers, You may have some trouble with the disc width as well but it can be done and will be well worth it, they would look good.
:cfrocks:
Glen.
1 - 8 of 8 Posts
