1 - 8 of 8 Posts
Forgot I had this in my shed. Lol. I should clean up more. Figure I'd build a Rat bike to go with my Rat rod. 1994 Honda XR200R. Subframe was rusted though so I have a good excuse to build my own. Found this remote resivoir shock of unknown origin, probably zx6. Wanted to build a narrow tired bike this time so I'm using a 21" Harley front wheel for a rear. Cut 3" off the front springs and 1" off the spacers in the forks.
Ha! We'll see. I building it mostly to pull behind my RAT,but judging by my past it will probably get ridden more than anything. if ya can't act like a hooligan, then how else will I act?
I think I'll start looking for an early yamaha RD tank. I just threw the old 200sx three wheeler tank on it cause it looked better than the plastic crap that came on it.
Another project of mine. working on the patina right now. It's a dropped '64 Dodge D-100 chassis,highly modified '69 Triumph TR-6 body,small block chevy/2spd. powerglide. once I find the right tank for the bike i'd like to do the paint/patina on the bike to match and build a single bike trailer for it.
Reactions: scottyp
I found a little time to work on the XR. Because I'm running a HD front wheel for a rear,I had to figure out a way to change the gearing.And mount the new sprocket. The 47tooth rear sprocket was way too big. So I dug around in my useless junk pile and found this 39 tooth kfx400 sprocket. Of coarse it didn't fit you silly shit! So I cut the hub section out of the HD and welded it in the kawazuki sprocket.pun intended. I also gave it a little offset to compensate for alignment. It is a 530 sprocket but I'm about solve that problem with my grinder.
Hmm.Thinking about using these two pieces of plate i got from work to build a subframe. Trim it to fit the frame and cut some cross braces and it might look like something.i don't know what, but something. Lol.
1 - 8 of 8 Posts
