The stock 900 pivot bolt fits. You need to make a spacer to fill the gap on the right side of the bike. I want to say it needs to be around 14mm wide. That's a rough estimate though. Mock it up and measure the gap. Use The stock shock and triangles. You'll need longer bolts and a couple more spacers for the triangles though. HTH
Yeah, I tried that suggestion. It didn't fit. Wound up being too wide. Had to shave it back to 14mm. And even at that width the pivot bolt isn't completly seated. The pivot bolt only makes it out of the lock nut by 3-4 threads.
1 - 7 of 7 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
