1081 - 1100 of 1589 Posts
I got lucky. :D
If the sprocket would have had one more tooth, or one less tooth, the pattern wouldn't be symmetrical.
Symmetry is all! When at all possible through an unreasonable degree of effort.
Sent from my XT1080 using Tapatalk
! :knucks:!
I wished I had the skills like you blokes have , this is just outstanding attn. to tha smallest details .
BLACK BELT
Discussion Starter #1,093
How much is the sprocket going to cost you in the end?
I never keep track of stuff like that. Takes the fun out.
It's a one-off sprocket from Talon in GB. The machine work wasn't cheap because the sprocket is hardened steel. Still needs polishing and DLC coating.
So, yeah- not a cheap sprocket. But, I get to do it my way.
Yeah, I thought I remembered reading back when that it was a one-off with a custom offset etc.
I imagine you won't go through sprockets very fast.
LOL Talon in Somerset UK , I used to maintain Rob Sartins Trial bikes(yamahas) waaaay back then. His Dad is George Sartin owner of Talon :) I think Rob runs it now .
BLACK BELT
Discussion Starter #1,096
Getting closer to welding the silencer brackets.
Need to cut the lateral supports and machine recesses to match the OEM subframe brackets.
Need to cut a 43 degree angle on the cross brace to fit it properly.
Also designed an aluminum strap which will bolt on, to align the silencers and the bolt holes during welding.
