Sadly, the bandit project I had underway has gone, so I am looking at refreshing my 1979 Moto Guzzi V50 Mk2. Yantosh is kindly helping out with a stem swap using some 1991 ZXR750 USD forks I am determined to use...axle will need sleeving which Yan is looking into so I can use the Guzzi front wheel as the ZXR one is wider than the stock Guzzi rear. Would have liked to use the ZXR front wheel but using anything other than the stock shaft drive for the Guzzi rules out any rear wheel swap of any significance.
Assuming it all goes together the Guzzi discs will not line up with the caliper. So, the long winded explanation leads me to asking if it is better to space out the discs from the wheel or space or make a new thick bracket for the ZXR brake caliper?
