1 - 5 of 5 Posts
This is how I mounted my straight bars on my 06 gsxr 1000 triples
I have a 03 GSXR 1000 but the 06 triples ignition mount is out of the way so I acquired some for $30. I bought some 1/4" aluminum scrap from a welder and made a template of the hollow part under the clamps.
i cut out two pieces with a band saw, dremeled the underside of the clamp and the backside of the plates.
JB welded both sides under the clamp.
I covered the top side with masking tape, found the center lines, vertically and horizontally. then off to the drill press to drill it out. Got the risers and bars and checked everything out.
The bolts on the risers were way too long (about 1/2") and I didnt want to use washers, so back to the band saw.
Also made a plate out of 1/8" aluminum to cover it all up and distribute the pressure.
one more 1/8" plate for the top cause I dont trust cast aluminum and i'm just anal like that.
Got the risers mounted, everything fits good, I'll get a pic of the bars with it and after I paint it all a pic on the bike.
And from the side
thanks for sharing. good stuff! :metal:
1 - 5 of 5 Posts
