1 - 9 of 9 Posts
Hi I'm Rob. I'm from VA and just purchased a 1984 Honda V65 Magna. The plan is to build a streetfighter/cruiser. So I've already started stripping all the rusty and unwanted or unneeded parts.
This is what I'm starting with.
Land vehicle Motorcycle Vehicle Motor vehicle Car
And this is where it sits right now. I still got a lot of work to go.
Auto part Vehicle Engine
I list of parts:
Gas tank? may try to reuse
Turn signals
Wire harness -
Rear brake caliper -
Rear brake line -
Front brake caliper bolts and rebuild kit
Front brake master cylinder - received
Clutch master cylinder - received
Throttle sleeve - received
Throttle grips
Handlebar mounted choke
Headlight
Front upper fork tubes
Coolant overflow tank
Speedometer face or guage OD
Tires front and rear
Right side grab bar
Spark plugs
Rear fender
Radiator shroud right side
Radiator cap
Rear shocks (Lowered)
7/8" Black Drag sport bars
And thats just the short list. I know as I go I will need other parts. Just trying put together a nice little ride, Any advice you can guys can offer would be a lot of help.
Rob aka Androidthug
Reactions: shinyribs and ROBBO
WELCOM in Rob' GL with yer project mate .
Thanks Everyone.
DrJellyFingers - I'm in Suffolk,Va
i cant fart
1 - 9 of 9 Posts
