Hey guys, as we all know, the UK is the mother of all Streetfighters !!!
...but the biggest custom parts market is still located in Germany
Therefor I thought, it might be handy for you to have a kinda dictionary available which contains commonly used terms while you browse web shops and what not.
Please feel free to post more terms and/or corrections you want to see in here.
Code:
english german
accessories Zubehör
adapter for coolant sensor Adapter für Temperaturanzeige
adapter for coolant sensor Adapter für Temperaturfühler
air cleaner Luftfilter
airbox Luftfilterkasten
axle Achse
banjo bolt Hohlschraube
battery Batterie
bearing Lager
belly pan Bugspoiler
billet grip CNC Griff
bleeder Bremsenentlüfter
bore Bohrung
bracket Halter
braided Stahlflex
braided Stahlummantelt
braided brake line Stahlflex Bremsleitung
braided clutch cable Stahlflex Seilzug Kupplungsleitung
braided clutch line Stahlflex Kupplungsleitung
brake fluid reservoir Bremsflüssigkeitsbehälter
brake fluid tube Bremsflüssigkeitsschlauch
brake lever Bremshebel
brake light switch Bremslichtschalter
brake master cylinder Hauptbremszylinder
brake pads Bremsbeläge
brake reservoir Bremsflüssigkeitsbehälter
brake rotor Bremsscheiben
cable Seilzug
cam chain Steuerkette
cam chain tensioner Kettenspanner
camshaft Nockenwelle
camshaft sprockets Nockenwellenräder
can Enddopf
carburetor Vergaser
chain Kette
chain - sprocket kits Ketten - Satz
chain breaker and riveting tool Ketten Niet und Trenn Werkzeug
clutch lever Kupplungshebel
clutch master cylinder Kupplungszylinder
clutch slave cylinder Kupplungsnehmerzylinder
coolant reservoirs Ausgleichsbehälter
counter shaft Ausgleichswelle
cushion lever Umlenkung
digital coolant temperature gauge Digitale Wasser Temperatur Anzeige
digital oil temperature gauge Digitale Öl Temperatur Anzeige
digital speedometer Digitaltacho
digital speedometer Digitaltachometer
digital speedometer magnets Digitaltacho Magneten
digital tachometer Digitaler Drehzahlmesser
dog bones Umlenkhebel
drive chain Antriebskette
drive shaft Antriebswelle
e-box for push button controls Steuerbox für Taster
e-box for push button controls Steuerbox für Tasteschalter
exhaust pipe Auspuffrohr
extended throttle cables Gaszüge verlängert
fairings Lampenmasken
fender Kotflügel
fender Schutzblech
flatslide carburetor Flachschieber
flatslide carburetor Flachschiebervergaser
foot brake lever Fuss Bremshebel
foot pegs Fussrasten
foot rests Fussrasten
fork cover Gabel - Cover
front sprocket Ritzel
fuel quick connect coupling Benzinschnellkupplung
gear lever Schalthebel
gear shift lever Schalthebel
generator Lichtmaschine
handlebar riser Lenkerböcke
handlebar switch housing Lenker Armatur
handlebar switch housing Lenker Schalter
handlebars Lenker
header Abgaskrümmer
header Krümmer
headlight brackets Lampenhalter
headlight units Scheinwerfer
heat matt Hitzeschutzmatte
heat wrap Hitzeschutzband
heel guards Fersenschützer Schlagring
hose clamps Schlauchschellen
hose cover Schlauchüberzug
ignition key switch Zündschloss
indicator lights Kontroll Leuchten
intake Einlass
intake boot Ansaugstutzen
license plate bracket Nummernschild Halter
license plate lights Nummernschild Leuchten
lifting kits Heckhöherlegung
lowering kit Hecktieferlegung
mirror brackets Spiegelklemmstück
mirrors Spiegel
muffler Enddopf
needle bearing Nadellager
oil pan Ölwanne
piston Kolben
piston ring Kolbenring
radiator guards Kühlerblende
rear hugger Radabdeckung
rear sets Fussrastenanlage
rear sets Fußrastenanlagen
rear sprocket Kettenrad
rod Pleuel
seat Sitz
seat plate Sitzplatten
shaft Welle
sheet metal mesh Gitter - Platten
shock Federbein
shock Stossdämpfer
single sided swingarm Einarmschwinge
spacer Distanzen
speedometer Tacho
speedometer Tachometer
speedometer gear Tachoschnecke
SSSA Einarmschwinge
stainless steel NiRo
stainless steel V2
stainless steel V2A
stainless steel V4
stainless steel V4A
stainless steel VA
starter clutch Anlasser Kupplung
starter idle gear Anlasser Freilauf
starter motor Anlasser
stem Steuerrohr
stem bearing Lenkkopflager
stroke Hub
struts Rahmenstreben
swingarm Hinterradschwinge
swingarm Schwinge
switchgear Lenker Schalter
tail light Rücklicht
tail lights Rücklichter
tail unit Heck
tail unit Höcker
tail unit Sitzbank
throttle cable Gaszug
transmission Getriebe
triple clamp Gabelbrücke
triple clamps Gabelbrücken
triple tree Gabelbrücke
turn signals Blinker
valve Ventil
valve clearance Ventilspiel
velocity stack Ansaugtrichter
velocity stack Trichter
wheel chock Transportständer
wrist pin Kolbenbolzen
yoke Gabelbrücke
