1 - 11 of 11 Posts
is not your fucking bro
when building a one off bolt on subframe how do people usually weld the subframe side shut so they can mount it. weld a angle iron piece on the end of the square tube ? what if its round ? what do the factories use for end pieces. i know what they look like ive got a ton of bikes but how do they do it.
I believe the end piece slides into the tubing and then it's welded at the end. Where you would get something like that I have no idea.
wheres FLINT??? :D
All star !!!
square tubing...you weld on a milled piece that is also square....same dimensions.... round tubing, you weld in a "plug" that most of has nearly the same OS, as the tubing ID.
Naked from the waste down
You weld in a piece that fits.
Rocket Science. lol jk
well when i asked the question i didnt know. welding in a "peice thats fits" doesnt tell anything. and still doesnt say how to mount it.
but trav is right.
Function IS Form
19 Z900, 88 Kat11
Mounting the subframe to the bike?
I was planning to drill holes and use a bolt and a nut.
1 - 11 of 11 Posts
