i going to go with the idiot light version
welded up a tray for the ECU
it fits in with room for rubber
but something has went slightly awry , it don,t sit parallel with the frame rail ... some surgery required
but you get the idea
mounting on one of the brackets I didn,t cut off
this is, or will be, the bracket for the coil, it,ll use the same mounting point
but right now I can only find one coil
got the brake lever on, not made the reservoir yet tho
tip over sensor fitted , granted i welded the bracket upside down so the rubber holder makes it look upside down, burrits not
