1 - 1 of 1 Posts
So I got the little 2 smoker running on premix which is not what I want to do due to the fact that the oil pump lubes the bearings and such. The problem is that the oil pump seems to have air trapped in it which is seen in the lines. I took off the lines that goes from the oil tank to the pump and cranked the engine by hand and there was air bubbles coming up, this would indicate that oil is being displaced? I tried to find a bleed screw but I'm not sure if there is one. I've been reading that some of the stuff inside the lines are delicate and disassembiling/assembiling the fuel pump is for the experienced. Not sure how true this is but I need a bit of help on this
1 - 1 of 1 Posts
